Are there any "standards" on the definition of synthetic?I don't think they'd be putting synthetic on the bottles if it weren't at least group III, my question comes though if you blend a high VI group II base oil like Exxon EHC with some group III and the resultant mixture has a VI above 120, high enough saturate content to be group III, and low enough volatile content to be group III wouldn't that technically make it group III?
Dexos 1.3 will have a 30% Grp2 limit … So, what drove that ?Are there any "standards" on the definition of synthetic?
If it is strictly VI, then perhaps the resulting mix is enough to be considered synthetic.
I would thing so, the resulting base oil meets the viscosity index and saturate limits Making it a group III. I don’t see what difference it makes. Other than understanding the sausage making process where someone figured out a way to use less energy and materials to produce the same product, which in most technologies we would call progress.I don't think they'd be putting synthetic on the bottles if it weren't at least group III, my question comes though if you blend a high VI group II base oil like Exxon EHC with some group III and the resultant mixture has a VI above 120, high enough saturate content to be group III, and low enough volatile content to be group III wouldn't that technically make it group III?
DuplicateI don't think they'd be putting synthetic on the bottles if it weren't at least group III, my question comes though if you blend a high VI group II base oil like Exxon EHC with some group III and the resultant mixture has a VI above 120, high enough saturate content to be group III, and low enough volatile content to be group III wouldn't that technically make it group III?
Group 3+ no question. The quality of these Warren Distributing oils have been proven to be beyond reproach.I recently read that these, and Amazon's, synthetic oils are Group II based, but I can't find the reference now. Is anyone able to substantiate or disprove this?
I need to better understand the material data safety info.
Grp3+ eh… again I ask why GM plans to limit the use of Grp2 in Dexos 1 Gen 3 …Group 3+ no question. The quality of these Warren Distributing oils have been proven to be beyond reproach.
Without reading any data sheet, I believe(key word..."believe") that SuperTech & Kirkland conventional oils are Group II PLUS, essentially making them a blend. Meaning the conventional may have a bit of Group III splashed in.I recently read that these, and Amazon's, synthetic oils are Group II based, but I can't find the reference now. Is anyone able to substantiate or disprove this?
