Supertech HM as a cleaner oil?
OH
I do like the MMO idea plus fairly cheap at Walmart for $3/quart or so. Not sure I'd use synthetic in this engine. Just conventional or syn-blends. Stick to a 5k/6 month intervals and check oil level religiously. Along with other fluid levels. It's amazing what simple things like that can lead to a long car life.
SilverFusion2010
Crawfordville FL
How long do you run the MMO before you change it out?
OH
You can leave it in the entire interval and use up to 20% of the total volume that it normally takes. Plus you can add about 4 ounces to the fuel as well. But check the directions on that one since I'm not 100% on the amount. Some on here just dose the oil for the last 500-1000 miles of the OCI but that's more of a maintenance dose. I'm not much of an additive guy either but this seems worth it. I need to buy some myself so a good reminder.
