Vehicle: 2000 Ford Econoline Van ½ ton
Engine: 4.2L V6 gasoline
Oil: SuperTech 5W-30 SL
Miles on oil: 3757
Time on oil: 6 months
Miles on engine: 46,951
this sample universal averages
Al 2 4
Cr 0 1
Fe 8 18
Cu 3 6
Pb 10 6
Sn 0 1
Mo 42 66
Ni 0 1
Mn 0 0
Ag 0 0
Ti 0 0
K 0 5
B 5 38
Si 18 17
Na 0 14
Ca 1578 1977
Mg 4 183
P 786 840
Zn 953 1017
Ba 0 3
SUS Vis @ 210ºF 57.1 56-63
Flashpoint 390 >365
Blackstone’s comments: The only problem found in your oil sample – and it is a minor one – is the lead reading as the dominant wear metal. Normal lead for this sample would be 2-3 ppm. 10 ppm isn’t anything to lose sleep over. Universal averages show typical wear metals for an oil from this type of engine after about 3,400 miles run on the oil. Your oil was 3,757 miles, and we found all wear except lead, at around average levels. Air and oil filtration look okay. This was 5W-30 engine oil with no gas, or antifreeze in it. The TBN was 3.3, showing active additive remaining.
My comments: This is my wife’s kid and grocery hauler. Almost 100% of the miles put on the oil were short trips <5 miles with the engine shut off each time so a little extra bearing wear is not surprising. The six month time span is from July to December.
Miles on oil: 3757
Al 2 4
Cr 0 1
Fe 8 18
Cu 3 6
Pb 10 6
Sn 0 1
Mo 42 66
Ni 0 1
Mn 0 0
Ag 0 0
Ti 0 0
K 0 5
B 5 38
Si 18 17
Na 0 14
Ca 1578 1977
Mg 4 183
P 786 840
Zn 953 1017
Ba 0 3
Flashpoint 390 >365
