Super Tech ST3614 - Photos
Originally Posted By: AuthorEditor
Maybe the Ecores are designed to blow out the media as a substitute for having a proper bypass valve? Plus, it gives you a great flow rate hot or cold!
I didnt just read this did i?
Originally Posted By: SuperBusa
I think it's called something like ... "sarcasm".
boy i would hope so,but you never know on this forum.
You might see if you can run the 3600 series of filter.
I have the 1MZFE in my 2003 Sienna, and am running a Wix 51516.....exact same dimentions....EXCEPT that is is longer......plenty of room in my application.
The WIX site indicates that the gasket is also IDENTICAL in inner diameter, outer diameter and thickness to the WIX 51348 that is listed as the WIX cross from the ST3614.
From Walmart.....another filter you might look at is the FRAM XG3600.
The Motorcraft FL400 (or FL400A or FL400S) are also a direct fit.....with the longer can.......the WIX site crosses them to the 51516.
So.....at Walmart.....the longer filters
ST3600 (Supertech)
XG3600 (FRAM)
FL400 (A/S also) Motorcraft
