Super tech oil filter quality
2024 Toyota R4 2.5
Have been an OE filter user, just recently I bought a couple of these Super Tech filters.
In comparison the supertech look very well made internally and on the inlet flow area... pictures shown below.
I should say I do short oil intervals because of my short local around town driving which seems to pollute the oil fairly quickly.
These are very low cost filters at $3.50 a piece.
I'm not looking for an extended oil service filter nor am I even looking for an extended oil service oil.
Just looking here to see if anyone has used these before and what their thoughts are.. thank you
Thanks, I was more or less wondering about the oil flow in comparison to the factory OE Denso filter to the supertech.
I did take a flashlight and really look inside the super tech and it looks built very well and a sturdy type of element along with the check valve but some have mentioned that they are not silicone type. Not even sure if that is relative anymore from the previous posts.
And I'm not going to lose sleep over this I spend more in a cup of coffee,!
These are made in the good old us of a!
If they’re E-core they will most likely outflow the OE filters
Favorite Champ model number. I cut one open too. Yes, the ruffles are present which is disappointing but for $3xx hard to pass up for my riding mower.
Super tech are a solid Made in USA choice. I would use them more often but they quit making the ST7317 for some reason, and don't have them for my 8.1L Chevy either.
I've used the smaller recommended replacement for the ST7317 oil filter, which is the ST6607 in my vehicles. No issues to report.
I would use them more often but they quit making the ST7317 for some reason,....
Not unusual for lowest tier filter option like ST to consolidate to smallest application that will work, here 6607. Saves shelf space while still offering a usable option.
they make the mp7317 and Walmart.com shows it as in stock, but at $9 you may as well get a wix or m1
I see a few still available on WM.com plus shipping. But at that price, better options available.
The PH 4967 gives the silicone adbv and is like $4. The construction inside looks the same but the Fram maybe has better efficiency.
It also holds the dinkiest filter element I have ever seen, downsized the can and downsized the element in the can. Personally I wouldn’t use it on a car.
I see by the picture next to the N1 it is the new small size. The N1 has far more media.
Seeing yet more, the US content is down to 75% now. They are buying materials from overseas and likely it means one place.
I'd run that before an orange can, looks like a much higher quality filter.
In this instance it's the same filter except the orange can has silicone adbv. Fram updated to this ST style recently.
Same efficiency as the Fram 95% @ 20.
It is a small filter.
