Super Tech ST4967 John Deere 4.9 Hours C&P
Show Me
Ecore w/metal endcaps. Love these filters. Excellent quality for $3 filter. They are small. Came off my 1991 John Deere 260 GT 4.9 hours. I had to open up the engine again so short run on this filter.
Thanks for posting. (y)
The ST4967 filter is the # for my Toyota Venza. I’ll have to look into these when my stash runs out.
And even though the ST4967 doesn’t have a silicone ADBV, my filter is mounted in the ^UP^ position anyway.
All one needs and done. Looks like ruffles. I opened the Fram ph4967 I got from Amazon, made 2024, looks the same but silicone rubber. They went up in price suddenly, double. They made it the same size as Toyota N1, quite a bit smaller. Maybe this one is still the standard size. I like they are usually at Walmart for the same daily price. The one I cut has the leak spring. I bet this one does too.
Nice photos and filter. What oil and filter went back on?
Thank You
Wish all Super Tech filters were this well put together. Thanks for the c&p.
This still has the "Leak Spring" or "Ruffles" on the leaf spring & I should've done a light test but overall can't beat it for the price right off the Walmart shelf. Thought about getting the Fram version w/silicon ADBV, for not much more, but I just don't need it for the low hours.
Yeah, I've seen these were spec'd for some Toyota's. SuperTech $3.88 Fram $4.18 w/silicon ADBV. Tough choice but I just don't need the silicon ADBV either. The ADBV was still pliable & held oil inside the filter & is horizontally mounted on the Kawasaki engine but for <5 hours that is expected. 😄
Have any pics of the Fram?
i went to return the Fram and Amaz returned my money without returning so I cut it open. In the meantime I had ordered a second one for under $4. So I have that one new and a cut up one. No pictures taken yet, but not impressed. Small element compared to Toyota N1, light leak, and glitter specs on the adbv where it sits on the base. Narrow element has no centering method so when it dropped in the can only luck centers it on the base.
I shone a bright led light through filter media samples. I could see a few twinkles on the Toyota, and maybe one on the Fram media.
I like Whip City but his 100x views of the filter media may not tell the whole story of all the media.
Just finished changing oil on my JD this afternoon. I have that exact same filter on mine. It has approximately 150 hours on it. I will change it out next fall. Those filters hold up very well.
Yes...liquid X585.
Using Valvoline 5-40 euro
About bought an older X485 I think? at local dealer $2500 w/1400 hours but it was real clean overall. Those tractors are very nice. This one is the old odd ball that had the goofy "emergency handle" for the deck lift. Thought it would be a good restore project & it's been a fun learning experience.
