Forever we had purolator filters at our local Walmart then all the sudden they were gone. Now the budget offering is exclusively super tech. Who makes them for Walmart and how are they? I know I'm the box it says good for 10,000 miles.
Your real first clue should be when you look down at the side of the box and the verbiage "Efficiency rating based on removing particles greater than 30 microns"
30 microns"
30 microns"
Is that good?
It's an oil filter that costs $2.96, that will filter your oil. It won't void your warranty, as long as you use it according to manufacturer's recommendations.
Originally Posted by slacktide_bitog
They are made by Champ
Some may be, but the ST10358 cartridge for my Toyota appears very nearly identical in construction to the corresponding Fram Extra Guard 10358, US-made version. The box construction is also identical. (Chinese-made Extra Guards of the same number are different.) With the Fram label, they cost over twice as much as the ST10358.
30 microns"
Is that good?
30 microns"
Is that good?
It is hot and sexy with a lot of marketing? No.
Will it do the job? Yes.
If an aftermarket filter is used while a car is under warranty, the car manufacturer could in fact deny engine damage warranty and make you go after the filter manufacturer. Safest thing to do to ensure that potential quagmire doesn't happen is use OEM filters while the car is under factory warranty.
As noted, back to Champ Labs made now, and majority are ecores. 6607 keeps the classic design. And the 9688 is a newfangled hybrid design, ecore cage, metal endcaps and Champ blue button poppet type bypass.
I've never tried them but I looked at the Super Tech oil filters at walmart and they seemed very well built for the price. I believe it said good for 10k miles on the box.
