Originally Posted by Ignatius
Originally Posted by jqgz
As others have said the Wix 57055 is a good filter choice. It has a very high bypass pressure. Fram ultra filters well but bypass valve is too low for Subaru specs.
Are you aware of the fact that an oil filter with a higher flow rate can utilize a lower bypass spec? The 23psi bypass spec that applies to Subaru's OEM oil filter (a Fram Extra Guard in a blue can) applies to THAT specific filter because it is flow restrictive as compared to say a Fram Tough Guard or Ultra Synthetic oil filter.
The Wix filters have a higher bypass spec because the have an even lower flow rate than Subaru's OEM oil filter. It even states on Wix's website that they have a 10 gallons per minute max flow rate. Wix makes a great product but Fram has proven to produce oil filters that have a flow rate of at least 14.5 gallons per minute to meet Subaru's specs. Flow rate is near infinitely more important than a bypass spec.
This oft repeated misnomer that every oil filter used on a Subaru MUST have at least a 23psi bypass to function properly needs to go into the ash heap of history.
Do you have a link to the flow spec on the Fram? Here is the link for the Wix specs: http://www.wixfilters.com/Lookup/PartDetails.aspx?Part=2166931
I would like to review the Fram flow specs as I was unaware they were superior to Wix. No flow specs listed here: https://www.fram.com/parts-search/T...WAAS4AdPgAyZMQEswACwAuAgCLp5ATzIAqEAF0gA
