In a lot of cases, these older EJ25 engines will leak externally and never mix oil and coolant.
Clutch and pressure plate already replaced since it started slipping at 77k miles. This is my wife's car, who didn't like using first gear, always starting it 2nd. I told her that would kill the clutch early, but she never believed me. Being married, I had to resist the urge to say, "I told you so"...there are a couple of other things you might consider doing while the engine is out. reseal the plate at the rear of the block. Also ,i would check the clutch and pressure plate, and if worn change it out too.
I decided to defer that for a few simple reasons:I would replace the HG's. just do everything at once so your're positioned well for another 100k miles. ...
these cars are junk. our 2002 outback had new cylinder heads-2 radiators -2 blown headgaskets all before 67k. .
My experience with 5 different N/A subies is, 1997 leaked coolant to combustion chamber, 2000, 2001, and 2003 leaked coolant externally. Most recently, the 2009 leaked oil externally. That gasket looked like it may eventually have gotten to mixing oil and coolant. I did the head gaskets with the timing belt on that.In a lot of cases, these older EJ25 engines will leak externally and never mix oil and coolant.
You can buy the Subaru Coolant Conditioner on Amazon. Price is very reasonable, and it does have a reputation for working.
