Any experience with aftermarket ATFs in a Subaru that requires ATF-HP (not the old Dex III spec ATF)? It's time for another 15K mile drain and fill (approx 4 out of 10 quarts) in my '07 Outback, and I'm deciding whether to go aftermarket or use ATF-HP from the dealer again.
My research has found the following that specify Subaru ATF-HP on the Product Data Sheet:
- Amsoil Synthetic Multi-Vehicle ATF
- Valvoline MaxLife Dex/Merc
I know that both are good products, and it's safe to assume that neither will damage my transmission.
I've you have tried either of those (or another product) where Subaru ATF-HP is specified, please post your results. Firmer, smoother shifting? Better gas mileage (one can hope)? Transmission exploded
? Let us know!
I asked on a Subaru specific forum, but got only 1 answer relating a positive experience with Amsoil. So I'm broadening my audience, hoping someone has tried the MaxLife in a Subaru that requires ATF-HP.
I have used the MaxLife on other vehicles that require Dexron III with excellent results, so I'm hoping to hear that it also works well when ATF-HP is spec'd. Nothing wrong with Amsoil, but it does cost more than MaxLife or genuine Subaru ATF-HP.
