What a nightmare this was. I figured i would make a post about my issues with this to possbibly help others that face this same issue...
First of all, i bought a car a couple of months ago because i needed another car. I figured after the snow stopped i would do an oil change. Easy, right? Nope. A nightmare.
Oil drain bolt was stripped so i had to buy a bolt extractor kit and use a 10" pipe wrench to get it off (took a couple days to get to that point). Then i put a band wrench around the filter and it kept slipping/slightly crushing so i waited for a better day to try again.
I tried a smaller band wrench (crushed it), 3 jaw wrench (ultimately ripped it open), rubber strap wrench, hammer/flathead screwdriver, hammer/chisel, screwdriver through it (tore it apart). All that was left was the metal plate. I sprayed it with liquid wrench.
I tried to make a tool made out of a bracket with screws in 2 holes to fit the holes on the plate... a screw snapped off in it. I tapped at it for a while with a hammer and screwdriver + chisel in the holes. Didn't budge. I tried to use a razor blade to cut the gasket but couldn't get to it.
Ending up getting the remains off with a 24" pipe wrench that my neighbor had. It was a Fram Extra Guard, BTW.
