Specifically, it's the brake failure warning switch on my MG Midget. It's a brass part with a shuttle valve in it that pushes one way or the other if there's a pressure loss in the front or rear brakes and trips a switch. There are two small O-rings sealing the piston, and apparently one of them failed and emptied the master cylinder after sitting for a week. Years ago I bought a rebuild kit for it when I overhauled the rest of the brake system, but I couldn't get the threaded part (the big hex bolt) off easily, mainly because there's no good way to get a grip on the rest of it. Any ideas on how to remove it safely? It's not a readily available part, so I don't want to damage it. I'm afraid of gripping it in a vice for fear of twisting it or breaking off one of the fittings. There are two fittings opposite the ones on top you see.
