JHZR2
Staff member
I've seen two concepts with the topic of removing the top nut from a strut to get its mount off.
One is that you must use the right tool, or at least a vice grip around the strut shaft to prevent it from turning, because the shaft turning will overheat and damage the seals in the strut gas cartridge.
The other is that an impact gun should be used to get these off, just doing a few hits at a time, and going that way is no big deal.
What's the truth? I've been watching youtube videos, so up you know how that goes. The guy in the autozone movies used an impact, the guy from the Netherlands in the euro. Monroe videos uses a special tool. I've read and seen mixed suggestions elsewhere.
I'm ok with buying a tool, even a pricy one, if it is usable for multiple cars, and I'm investing in a good spring compressor because I'm sure that much first strut job won't be my last....
But not sure how different the nut removal job is from make to make.
Recommendations?
Thanks!
Recommendations?
Thanks!
