99 Ranger 4.0 OHV, no mods.
Truck was starting at the flick of the switch, then it started to take several seconds. Checked the battery...bad. Replaced battery with Duralast Gold...battery still good...problem is still there as well.
Changed the fuel filter with a WIX...no improvement.
I checked the fuel pressure. Goes to ~10-20psi when key is turned (but not started) for about 1-2 seconds, then there is an audible click (relay I believe), and the pressure drops like a rock. Will build up more pressure with multiple cycles. The pump does go off with this click.
Now the strange part. The truck will start and seems to run fine once there, BUT the fuel pressure is at a steady 65psi no matter the RPM. The book calls for 35-45psi.
So I think fuel pressure regulator. Replaced it with an OEM part...no change.
And there is vacuum at the control hose.
Any ideas??
And is the fuel pump supposed to click off after just a few seconds with the power on?? I thought it was supposed to stay on once the key was turned?
Thanks.
Any ideas??
Thanks.
