I installed a pressure gauge on my Motorguard filter that is in my 1991 Benz diesel. I was expecting to see a fairly constant pressure reading. I have found that the pressure ranges from 50 PSI when the oil is cold to zero when the oil is hot. (can’t see that the needle has moved) I was thinking that the temperature or viscosity would not matter since the oil has to go through an orifice first before the oil getting into the filter housing. If the oil is thick it should enter slowly to compensate for the fact that it is also harder to get through the filter. The pressure change with temperature therefore seems very strange. I was hoping to see a reading when the oil was hot in order to see if the filter plugs with time. Maybe someone with fluid dynamics training can explain this. My only explanation is that when the oil is thicker it packs the fibers together harder making it more difficult for the oil to get through.
I made a little machine to re-wind my rolls in order to get tighter rolls of paper. I can fit one and a quarter Scott 1000 rolls in the housing after they are wound tight.
