straight 50 weight in my Milwaukee 8
I don't know where you can get a good full synthetic straight 50 motorcycle oil, just about all are 20w-50 and that's fine to use. I believe you can use 20w-60 as well.
Dennis Kirk sells straight 50w Klotz full synthetic for V twins. For what it’s worth.
HD 20w50 if you want to go by the book
or
15w50 HDEO if you want to sort of go by the book being its diesel rated
or
15w50 Mobil 1
Or any number of 20w50 oils, such as Mobil 1, Valvoline etc. motorcycle oil
No way would I use a straight weight oil
Adding an oil cooler is not going to help the heat you feel off the engine which you may know. It maybe help reduce oil temperatures a little but being you have a liquid cooled engine I doubt its critical, cant hurt but would be good for you to get an oil temperature gauge (if possible on an M8 to see if its needed.
I have a 2016 FLSS bought new
I have run straight 50 since the 1st service, plus an HD oil cooler.
No problems, virtually never had the 1 cylinder cooldown run, unlike a lot of bikes i run with
Read the book, it has expert oil recommendations re ambient operating temperatures
