Originally Posted by tundraotto
- and a TBN of 7.0
Naah.
What is the advantage? To pay more?
I hear you, but to be fair it's the same TBN as MAG 1 10W30 full synthetic
https://mag1.com/products/passenger...l/mag-1-full-synthetic-10w-30-motor-oil/
Which is the same as SuperTech 10W30 full synthetic, and that did fine in this 6000 mile UOA (2019) from a 2008 KIA Sportage with a finishing TBN of 2.7
https://bobistheoilguy.com/forums/ubbthreads.php/topics/5277530/1
Quote
MAG 1 FULL SYNTHETIC 10W-30
INDUSTRY/OEM SPECIFICATIONS
API SN
Approved
API SN Plus
Approved
ILSAC GF-5
Approved
API SJ, SH, SG, SF
Meets Requirements
API SL
Meets Requirements
API SM
Meets Requirements
Chrysler MS-6395
Meets Requirements
GM 4718M
Meets Requirements
GM 6094M
Meets Requirements
ILSAC GF-4
Meets Requirements
TYPICAL PROPERTIES
Boron, wt. %
ASTM D5185
0.018
Calcium, wt. %
ASTM D5185
0.132
Cold Cranking Simulator at (°C), cP
ASTM D5293
3884 (-25)
Color
ASTM D1500
3
Flash Point °C
ASTM D92
210
Flash Point °F
ASTM D92
410
Foam Seq. III (Tendency/Stability), mL
ASTM D892 (Opt. A)
0/0
Foam Seq. II (Tendency/Stability), mL
ASTM D892 (Opt. A)
0/0
Foam Seq. I (Tendency/Stability), mL
ASTM D892 (Opt. A)
0/0
Gravity, °API
ASTM D287
33.86
High Temperature Foaming, static foam
ASTM D6082 (Opt A)
20/0
High Temperature / High Shear Vis at 100°C, cP
ASTM D6616
7.17
High Temperature / High Shear Vis at 150°C, cP
ASTM D5481
3.04
Magnesium, wt. %
ASTM D5185
0.043
Molybdenum, wt. %
ASTM D5185
0.004
Nitrogen, wt. %
ASTM D4629
0.086
Noack Volatility, % loss
ASTM D6375
8.2
Phosphorus, wt. %
ASTM D5185
0.077
Pour Point °C (°F)
ASTM D5950
-42°C (-44°F)
Pumping Viscosity at (°C), cP
ASTM D4684
13,900 (-30)
Shear Stability, Final Viscosity in cSt
ASTM D6278
8.99
Specific Gravity @ 60°F (15.6°C)
ASTM D4052
0.8557
Sulfated Ash, wt. %
ASTM D874
0.92
Sulfur, wt. %
ASTM D4951
0.3
TBN, mgKOH/g
ASTM D2896
7.0
Viscosity @ 100°C cSt
ASTM D445
10.14
Viscosity @ 40°C cSt
ASTM D445
61.71
Viscosity Index
ASTM D2270
151
Zinc, wt. %
ASTM D5185
0.085
Notice how the add packages of Mag-1 SAE 30 and Mag-1 10W30 full synthetic look the same. That's because they probably are, as the package was probably developed as a matrix solution to multiple oils, as this is a more efficient development method.
I would have no problems going 6000 miles on Mag-1 SAE 30, and maybe more with a UOA along the way.
To what advantage ? Higher HTHS, Lower Noack and 100% shear stable as it's the polymer VII that shears, not the base oil.
