Broke in my pressure washer with this. (first 50 hours) Now I have conventional castrol gtx 10w30 in it, mainly because that's what I had laying around.
It’s what I use in my generator, and other OPE.Mobil 1 0W-40 hot or cold, it just works!
I did. My 4gpm gx390 pressure washer runs at 4,000rpm, runs wide open throttle and hits 260f on fairly mild 80f days.15w-40 would be better. Someone on here checked the temp on a hard ran pressure washer and the oil got to about 230f or so. That'll make a 30 grade into a 20.
SAE 30 is probably fine as long as it doesn't get real cold where you are.When I purchased my Generac 2200w generator , I asked the dealer what to use . He handed me a bottle 30w oil .
We don't get that cold here .SAE 30 is probably fine as long as it doesn't get real cold where you are.
Check out this link.
A generator in very cold temps somewhere between -17f and 0f had conventional 10w40 oil in it and felt the the engine was locked up.
Other generator with synthetic 5w30 the oil was so thicc at -17f that the engine would turn over but refuse to fire due to lack or cranking speed (by hand).
https://bobistheoilguy.com/forums/t...-generator-at-or-below-0f.378025/post-6751363
SAE30 oil would be even thicker in cold temperatures.
I feel like this is the most widely covering oil for all my applications. I'd have a harder time finding an application it wasn't suitable for than one it was suitable for.Mobil 1 0W-40 hot or cold, it just works!
An sae30 oil at freezing is going to be almost as thick as a 5w-xx oil at 0f.We don't get that cold here .
That's just incorrect or I have been lucky. I am in Louisiana, so my running schedule is similar to Florida. I run 5w30 synthetic in all my ope. 7 years and 243 hours on John Deere D110, 60 hours on John Deere X350, Honda power pressure washer ran 10 hours in hot sun at one time, Generac 7500 running 2 houses after hurricane or after power failure and tiller working garden. Not one oil related failure due to 5w30 synthetic. I also have several push mowers used. Been running ope with 5w30 for as long as I can remember and other things take out equipment out of service.The post hurricane generator failures were almost universally on 5w30, as required. most have low oil sensors. It was stagnant hot and humid air, coupled with 24/7 high load operation. Such as a 4500W water heater on a 5000w gen.
I had 2ea Honda powered water pumps fail on the required oil. The dealership covered the engines, as they only made it a couple of days each. The idea that an air cooled engine without an oil cooler or oil pump, run on 5w30 automotive oil, at near 100% of rated output, on a hot and humid day, can hold up with 270+ degree oil temps is just incorrect.
A 5w30 isn’t good enough for hot temps? I think the key would be to keep the oil changed every 50 hrs or whatever is suggested.
In the event of a long term outage, I’m guessing an oil change every 2-3 days isn’t on people’s minds.
If the engine is a splash lube engine with a little oil dipper fastened to the connecting rod cap, I wonder if 15w40 is "splashible" enough.
I've been using 5w30 mostly Royal Purple HPS in our Craftsman 17 hp lawn tractor for years now with no issues
Oil is drained before storage and filled up and ready to go in the Spring.
What does every one think about doing a franken mix in a pressure washer? I am considering Amsoil 5 w 30 with Mobil Delo 15 w 40 full syn? I am also considering topping off my Generac standby Generator with the 15 w 40 . It has 5w 20 in it from the dealer. I live in SC and it gets pretty hot here. I just don't trust 5w 20 in the 90+degree heat. (Or the 5w30 either for the pressure washer.) Or am I overthinking?
Sorry, but couldn't you go 50 to 100 hours on a change, especially if running a quality synthetic?I change the oil everyday when running the generator (almost) non stop during a power outage.
Probably not without an oil filter.Sorry, but couldn't you go 50 to 100 hours on a change, especially if running a quality synthetic?
