store brand motor oil
Show us a pic or it didn't happen, and you can drop this thread.
Originally Posted By: engineer20
There is sludge when I open up the oil cap.
With the uncertainly and indecisiveness this guy shows, can anyone here imagine what it would be like to be a waitress taking his order in a restaurant?
"I'll have the cheeseburger with lettuce and tomato with a side of sweet potato fries. Wait, the regular fries are .50 cheaper? What's the calorie difference? Only 5 calorie difference? Ok I'll take the sweet potato fries. I'm allergic to gluten, how would a wheat bun effect me? Would it hurt me? I'll have the white bun but I'm going to change my cheeseburger to the western cheeseburger. No lettuce or tomato, just onions and pickles. On the other hand I think I'll have tater tots."
I'd imagine this would just be a short snippet of it.
You should write comedic segments for sitcoms!
Guys, we should be kind. We all obsess over trivial oil things, and some of us just have experience that glosses over our OCD. That being said, engineer20, as I already said, make it simple, easy, and cheap.
I don't do a lot of playing with cleaning additives of any sort unless I have nothing to lose (i.e. I plan on a rebuild anyhow, then I don't worry about solvent flushes or the like). I'm not even going to get into the Seafoam debate.
If you want to safely and effectively clean an engine, in my view, there are only two best practices. The first is to do short OCIs with a decent oil, be it an HDEO, a HM of some sort, or even any sensible yet cheap SN/GF-5 oil out there. I used HDEO and MaxLife 5w30 in my F-150 (depending on the season). This worked well, but be aware that there are limitations. Splash lubrication won't get everything clean, and a plugged oil gallery is a plugged oil gallery.
The second option is to disassemble and do manual cleaning. There is no product in a bottle that will beat this. However, this is far more labour intensive than any product in a bottle. Hence, products in bottles, even with dubious claims, are very popular.
Give yourself some time with some short OCIs and see how it goes, first. You won't have miracles in two OCIs though, I assure you.
ANd i care because i want the car to last a while and i heard synthetic makes your car last longer
Well played, sir.
You guys, E-20 may not admit it, but it's trolling the heck out of you and y'all are falling for it, hook, line and sinker.
Is that a fact, and all this time I thought he was just full of questions.
Come on, give me more credit than that.
That's why I thought it was a good idea for E-20 to come here...for your "feedback"...
@ ToyotaNation, with its name and rep as an owners' forum/website, we have to take such threads/posts carefully, lest someone screw up as E-20 did more than once (re: Seafoam use/coolant drain-fill) and then claim WE told him to do it that way...
Well, y'all keep feeding the guy, so I thought I'd point out what was obvious to me.
Again, I, not trolling. I successfully got a smoke show from the camry but not on the taurus
All I wanted to know was if sea foaming incorrectly was bad and if I needed an oil change afterwards. After seafoaming, the camry runs like new and I'm highly satisfied and I want the same results from the taurus
Personally, I like to run pure rendered bacon grease in all my cars. Smooth running, and smells great!
..not to mention all the bacon I get to eat to make my next oil change. MmmmmM!!!!
I'm just asking, I heard the Bacon from Whole Food Market has better grease then bacon from Albertson's, I read it is closer to 10w/40 but I may need bacon grease closer to 5w20 in the Michigan winter, do you think I can get this at WinCo or should I stay with bacon from Albertson's. Is name brand bacon better than local bacon as far as the bacon grease and what filter should I use? Someone told me the red can AKA the Devil Can is the best one to use for bacon grease but I heard you have to sell you soul to get it.
Name brand bacon is BY FAR better, get the low fat thin cut bacon, it's closer to the 0w20 the OP's Camry is back specced to
But what about turkey bacon? Is it better or worse because it's low fat? Is it beneficial for a 3k? Is it suitable for a 5k oci? Is store brand as good as name brand? Should I step up to a filter with a silicone ADBV, or will the nitrile be OK?
What about cheap formula shell? How does that compare to Pennzoil? Formula shell is store brand cheap.
Only thing cheap about it is its price, Shell doesn't make a bad oil. Obviously Pennzoil is Shell's high end motor oil, with Quaker State right behind it, but there is nothing wrong with their regular Formula Shell oil.
Gotta be careful with the turkey bacon, as its lower fat content requires eating MUCH more of it for the same usable output. Also, the turkey stuff tends to have a higher NOACK number.
Lastly, too much of the turkey based stuff and your car will start to feel sluggish.
