First UOA on this car. Wanted to check performance of SuperTech 5W30 dino oil with SuperTech 4967 oil filter @ 3500 miles installed 7/1/09. Will extend OCI to 5000 miles on the 96 G20 Infiniti 2.0L four cylinder with 243,947 miles. Bought the car new and never had any internal engine work performed. ST 5W30 oil & filters used since 228,510 miles with 3000 mile OCI. Last two air filters replaced @ 212258 & 243413 miles. 1/2 of my driving is 5 mile (spirited) round trips to local stores including Walmarte'. Have a 04 ZX3 2.3L Focus with 75K that should have 5000 miles in December on ST 5W30 & ST3614 that will also have a UOA performed. ST Oil/filter changes cost around $11.
Wanted to share the Blackstone report and hear comments about this oil/filter combination:
Bill, Wear looks great in this initial sample from your
Infiniti. You've kept your oil changes around 3,500 miles though you should easily be able to go 5,000 miles next time.
The flashpoint was low enough to show fuel in the oil, though this is likely from driving around town. No coolant or
moisture found. Nissan makes nice engines, and at nearly 250,000 miles, this one isn't an exception.
MI/HR on Oil 3507
MI/HR on Unit 243947
Make Up Oil Added 0
Date 10/27/09
ALUMINUM- 2
CHROMIUM- 1
IRON- 5
COPPER- 1
LEAD- 3
TIN- 3
MOLYBDENUM- 115
NICKEL- 1
Manganese- 0
Silver- 1
TITANIUM- 0
POTASSIUM- 0
BORON- 3
SILICON- 13
SODIUM- 6
CALCIUM- 1478
MAGNESIUM- 6
PHOSPHORUS- 537
ZINC- 680
BARIUM- 0
cSt Viscosity @ 100°C- 7.82
SUS Viscosity @ 210°F- 51.8
Flashpoint in °F- 335
Fuel %- 1.5%
Antifreeze %- 0
Water %- 0
Insolubles %- .04%
TBN
MI/HR on Oil 3507
Make Up Oil Added 0
Date 10/27/09
ALUMINUM- 2
CHROMIUM- 1
IRON- 5
COPPER- 1
LEAD- 3
TIN- 3
MOLYBDENUM- 115
NICKEL- 1
Manganese- 0
Silver- 1
TITANIUM- 0
POTASSIUM- 0
BORON- 3
SILICON- 13
SODIUM- 6
CALCIUM- 1478
MAGNESIUM- 6
PHOSPHORUS- 537
ZINC- 680
BARIUM- 0
Fuel %- 1.5%
Antifreeze %- 0
Water %- 0
Insolubles %- .04%
TBN
