ST 4967
panhandle of florida
I just put one of these on my Corolla and filled it with Mobil 0w-40. I had originally planned to use a Fram EG for the longer OCI I want to run but when I went to put it on the car it refused to thread. How long would you guys run this filter? Its about 1/3 shorter then the Havoline(purolators) I've been using.
Bill in Utah
Staff member
UT
I run them 7-8k miles in my Corolla. Cut open everyone and my UOAs come back excellent. Excellent filter. Use with NO WORRIES. Bill
Bad Axe, MI
Not 1 mile when one can get a wix/ng for the same to little more $$ and have a real filter,the ones i cut open are scary man. far from excellent,,a M1 or Eao or P1 or upf etc,etc is excellent,not a st.
Iowa
I've been running them on both our Corolla's lately (00/05). Never had a threading issue. About 5K OCI's, no problems. I'll be going to Wix though because I can get them for a little more. No complaints about the Supertech's though.
Bill in Utah
Staff member
UT
Show me the bad filter... To the OP. I stand by what I said. Unlike others, I've used them and cut open each and every one. And here is the good Wix I used. (I had a bad one also) Take care, bill
Bad Axe, MI
ok... you have the older version when they were a tad better with steel end caps,the new one's(e-core) today at my store suck,[censored] glue job and super thin/lacking media. ..nice glue job.tears off very easly, you can have 'em. oh and i cut all mine open too. ;\)
Bill in Utah
Staff member
UT
The ST4967 is NOT a ecore. Never was and for now never will be. Only the larger ones are. The smaller ones (7317, 4967, 6607) all have end caps. Here is a few photos of ecores. (I have many threads and photos, never any end caps not glued. Each and every one took effort to pull them off) Here is a shot of a new one. Look at the bottom, all the ends are welded to the end cap.. Again, I've run many of these over the years and never a problem. Also, to repeat... ST4967 has ONLY metal end caps. So does the ST7317 and ST6607. Bill
Bill in Utah
Staff member
UT
 Originally Posted By: panthermike
Hey Bill, is that an older ST4967? The ones I've been using look different on the outside.
In the photo above, yes that is a older one. The newer ones are the same inside, different label.
Pottstown, PA
Ecores are only used, as Bill said, in 3" diameter filters or larger. Unless they've added a new line, all other filters of <3" are now "blue button" bypass valve filters.
pbm
New York
I don't think the ST 4967 comes in an e-core. I preferred them when they had the spring instead of the current blue-circle but i would use them with no worries for 5K.
Bill in Utah
Staff member
UT
You are correct. The 4967, 6607 and 7317 (those are the one I use the most and KNOW for a FACT) are all non-Ecore But I run Ecores in my Moms Chevy and Uncles PT cruiser with never a problem. And I do open each and every one.
Has anybody used the oversized ST 3614 equivalent in a Corolla?
Nope, never felt there was a need. The 4967 works like it should. If Toyota felt there was a need to run a larger filter, they would have spec'd it IMO. Take care, Bill
The Old North State
Bill, thanks for posting the pics!!!! Being from Mizzou(not), a picture is worth at least 1000 words, for a show me guy. As Tony says They'reee Grrreatt! Seriously though, they are. And some great info on ecore-non ecore. I use 7317 non and 3614 ecore. I prefer the 7317 design BUT I'm using a ST3614 right now, with no worries. I just prefer the metal endcap design. Now, explain the reasoning for ecore on larger ST's and non on smaller ST's? Just curious. Lots of good information about ST filters in this thread. \:\! Thanks Bill and Gary.
Bill in Utah
Staff member
UT
A little reading for you! Ecore press release More info on Ecores And with photos! The reason for the smaller filters not yet being ecore is prob cost to switch over the line. Like I said, Ecore ARE good filters. Take care, Bill
