Spray Sealant Question
CA
My wife's Accord was coated with CQuartz UK ceramic coating in 2015. By 2018-19, the product began to fail, which is no surprise since the product was only rated for 2 years. Since then, I have used various "ceramic" sealant products at every other car wash. Sometimes it is a spray-on/rinse-off product, sometimes it has been a spray-on/wipe-off product. The car gets washed 2-3x per month so the paint gets treated at least monthly. I think there is a heavy buildup of SiO2 based products on the paint right now. Both dirt and water bead off as well as a vehicle that was coated with a real ceramic coating.
With the current regimen, is there any reason I should apply a real coat of paint sealant (or paint coating)? Or is there adequate paint "protection" by continuing the current regimen?
Depends what you want out of it. With that regimen the vehicle will always be glossy and always bead/sheet water. That's enough for most people. It won't be as resistant to road film or repel dirt as easily as it would with a real coating or sealant but with attention 2-3x per month I'm not sure it matters.
