Spit Spit Spit Spit Chew Spit Spit Chew Spit......
Kind of the same but different,why is there the need to spit into the urinal before taking a leak?? Every time some guy comes in it's spit,unzip...etc!
What is with all the spitting??
Now that I can't explain.
Most likely it's an attempt to display manliness, as the OP mentioned. I can't think of any practical explanation for spitting in a urinal.
What? You don't have to prime the pump???
Never discovered a nasal or (if you wear one) mustache hair in phlegm when clearing your throat???? What do you do? Swallow it, or reach in there and dig it out?
Bob
No.
Maybe I need to pay more attention to sputum.
Originally Posted By: tom slick
It's interesting how chewing tobacco, spitting, and baseball were together long before pro baseball or TV was invented but society has changed and we now find the tobacco usage unacceptable. I don't think it evolved, I think we just notice what used to be considered normal.
Yup, this applies to smoking in general too. When I watch a TV show or movie from the 50s or 60s, it's amazing how much smoking is going on.
Bob
UMMMM ,no.... I will as was mentioned pay closer attention to my sputum. But alas, I do not spit nearly as much as you seem do deem normal.
Swallowing nasal hair with no ill affects yet,
BamBam
Bob
Really wouldn't hurt to swallow it.
There are only a few good reasons to spit:
1) a bug flew into your mouth (now many can be swallowed for protein, but if it's a bee, you'd be in trouble, so better spit to be on the safe side).
2) you just bit into a rotten piece of fruit (this could be swallowed too if you manly enough, but spitting is justified).
3) You accidently popped an Ex-lax tablet into your mouth when you meant to take a Viagra.
4) You discover broken glass shards in your food.
Swallowing phlegm, expecially when you have a bad cold, may be healthful and certainly it's better to snort up the runny nose stuff and swallow than to blow it out into a rag, especially in public.
Well, at least the ballplayers are just spitting on the field. Would hate to see a new habit of barnyard blows (plug one nostril and blow the contents of the other on the ground, then repeat for other side).
