Originally Posted by sloinker
Ahhh yes. 2% across the board. Wonder if M1 actually sells any of these formulations out of one of their own bottles?
So would 3% be better, or 4%?
Don't know.
Sometimes you need more. ... Tell me if this would make a great racing oil: .......
There is a very interesting patented oil out now that uses about half ester in its base oil, along with other base oils that have a high aniline point, all for piston carbon dissolving action. Valvoline Premium Blue Restore 10w30:
Originally Posted by Gokhan
Code
20% PAO
50% polyol ester (POE)
10% alkylated naphthalene (AN)
0% viscosity-index improver (VII)
20% additive package
(Likely formulation according to the patent)
Polyol ester (POE) and alkylated naphthalene (AN) are base stocks with high solvency, which perform the engine cleaning.
The additive package is the standard used in other Valvoline oils.
Note the absence of viscosity-index improver (VII). It's technically a monograde oil.
It's a SAE 10w30 HDEO with KV100 = 12.0 cSt and HTHSV = 3.9 cP. However, since it has no VII, it can also be legally labeled as a SAE 30.
NOACK = 5.4%
If you think you need it, give it a try. It should work. Don't neglect to get an oversized (if possible), high-capacity fully synthetic oil filter.
Valvoline US patent US20170029734A1... deposits in internal combustion engines
