Speccing battery terminals and lugs
JHZR2
Staff member
New Jersey
Hi,
Im going to be looking at replacing some battery cables with bigger ones, on my 24 year old diesel, and some heavier ones on some of our other older cars where it may help out with power/grounding.
Anyway, Ill try to buy from http://www.custombatterycables.com/parts/just_parts.htm
But it is not clear how I spec out terminals and lugs for my battery/frame ground points. Do I spec lugs by the diameter of the bolt that it is attaching to the frame with? Do I spec the terminals by the ID of the terminal when it is bolted down to the battery?
I will be going with at least single aught cable, short runs as possible, and perhaps double aught for the diesel. but I need to spec the terminals/lugs to fit, for this custom job, and don't have a clue how to.
Any insight into how to best do this, would be most appreciated.
Thanks,
JMH
There is a "contact us" link. You might try to ask them that question. Their speed of response might tell you something about their business practices as well.
