It's actually not.What's up with the plug on the left? That gap is huge!
Any particular reason vs NGK Jeff?Densos are my favorite plugs.
I've purchased 3 sets of fake NGKs off Amazon, that I know of. Of course, that's hardly NGK's fault. It did sour me.Any particular reason vs NGK Jeff?
Wasted-spark ignition, or coil-on-plug?I've purchased 3 sets of fake NGKs off Amazon, that I know of. Of course, that's hardly NGK's fault. It did sour me.
I no longer use Amazon for spark plugs.
Fun fact: our beloved 2006 TSX with the mighty K24 4 banger came from the factory with 2 NGK and 2 Denso plugs.
NGK makes great plugs. I'm sure I will buy them again, just not from Amazon.
Coil-on-plug. I guess the assembler just grabbed some plugs and went for it. The K24 now has 235K on the clock and does not burn a drop; it's lived on a steady diet of Mobil 1 5w30 at 4,500 OCIs. Great car.Wasted-spark ignition, or coil-on-plug?
If wasted-spark, I would guess the Denso were double precious-metal, and the NGKs were not.
If COP, that was likely Honda treating both plug manufacturers equally.
There are some checks out there, just Google NGK fake plugs. I found out the hard way; they started throwing CELs.This might be a Gray question, but how do you know if you're getting a counterfeit spark plug.?
And any suggestions were to get a non counterfeit one?
It's difficult. As stated, buy from B&M or RA. Even then, look for signs someone has handled (possibly swapped) them.This might be a Gray question, but how do you know if you're getting a counterfeit spark plug.?
Perhaps I'll just pick up plugs from the dealership when my miles add up.There are some checks out there, just Google NGK fake plugs. I found out the hard way; they started throwing CELs.
My practice is to not buy plugs from Amazon. RockAuto or local parts stores are safe, in my experience.
I once got fake "Denso" coils for my old Tundra from Amazon as well. Sheesh. If it's too good to be true, it probably not true.
right one, tooWhat's up with the plug on the left? That gap is huge!
