Originally Posted by PimTac
Originally Posted by BrocLuno
This whole thick/thin thing is way to "emotional" ... Folks are making oil decisions based on a "feeling" that it will do XYZ ... It's like brand loyalty - fan boys/girls.
What does the engine want? It's based on actual bearing numbers (clearances, wear, operating environment), piston to wall clearances, and type of valve train. If you live in Minnesota it can be one thing. If you live in San Diego, it can be another.
% heat generated by increased viscosity is somewhat pertinent to operating environment, but offset by HTHS capability.
It's all about keeping the metal bits from actually touching in the operating range under the loads that are being experienced. If a NASCAR engine could live on 0W-20, those guys would have made the switch years ago. Drag Racers are trying to live with "light oils" as they know it means less drag ("free HP"), but they are paying a steep price to learn how.
Almost all engines are actually designed around the equivalent of SAE 30. BMW have tried to tighten bearing clearances to allow constant use of thinner oils, ditto Audi. But in both cases it has not been an overwhelming success. Fine for mom chasing the kids and doing in-town errands. But falls on its face when pushed hard for hours on end like cruising across the US western deserts at elevated speeds with the AC on. Which is why all the makes have some caveat somewhere to use heavier oil on track days, etc. It's about the Operating Environment ...
Thank you for this excellent comment BrocLuno. This should be nominated for comment of the year.
Agree PimTac... Great, great post by Brocluno.
