It's always nice to read about S2000's so I could not resist the revive an old thread.
One thing about the engine oil.
The F20C and the F22C are high revving engines.
This does not mean they need 'racing oil' or that they need to be protected by thick oil.
Quite the contrary, actually.
Journal bearings create their own oil pressure by rotating, as high as 20 bar.
No engine oil pump is going to create that, it's not even needed, the oil pump's job is to deliver oil to the journal bearings.
Going by the standard oil recommendation in 1999 (10W-30) I can't see it otherwise: Honda designed the F20C/F22C around a 10cSt oil.
30 weight / 10 cSt oils @ 100C - as recommended by Honda - are thin enough to flow fast through all the small passages towards the bearings, pushed by the oil pump, and are capable enough to create the needed internal oil pressure once inside the bearings.
The oil pump is a positive displacement pump and this means it needs - and has - a safety valve, or bypass valve.
The F20C bypass valve is a spring loaded piston that is pushed open by oil pressure, as simple as that , pressure x area = force.
Positive displacement pumps also deliver more oil and at a higher pressure as the rpm's go up.
It's also clear a thicker oil will produce higher oil pressure.
Combine this and you will (should!) conclude that using a thicker oil will open the bypass at a lower pump rpm.
In other words: a thicker oil will reduce the amount of oil flowing through the engine at higher rpm.
When you need it most there is less oil going around.
What I mean is, there is less oil delivered at all the bearings, there it less oil sprayed up under the pistons to cool them, there is less oil removing heat from where it's generated.
Honda updated the oil jets on the early MY engines because prolonged high rpm showed an overheated #4 cylinder.
As we live in 2024 now, but even in 2022, the 1999 10W is obsolete.
So the best choice for the F20C/F22C is 5w30 or 0W-30, IMO the thinner when cold the better.
