Hi everyone
1- What is the main different between SN, GF5 & Dexos? does the las one cause less sludge & keep more gasoline?
2- If I want to compare 2 or more oils. how can I know the best if have these physical Characteristics: viscosity index, pour point & flash point؟
3- If car manufacturer recommend to use abc oil & I found oil for xyz has the same viscosity but is better than the first one in phiscal Characteristics. what is the better for my car؟
4- If I have 2 or more oils. 1-Does the oil which has the highest viscosity index cause the fewest sludge at the same drive conditions? 2- and I can drive more milage?
5-We know that oil decreases in other word: evaporates or burns
If it burns: Does that mean that he turns into sludge and affect on oil pump permormance?
6-If oil decreases 450 ml per 3100 km. is this acceptable? And what is the acceptable?
7-In normal driving conditions, what is the distance or in how many km I have to change oil? And in difficult conditions?
8-If I have to change in 3000 miles and I drove for 2500. after long time: is this good because it causes less sludge?
9-Does weather temperature greatly affect on oil viscosity & I have to change oil before defalt time or milage? Or not because engine temp 150-190 degrees Celsius?
thank you
thank you
