- Joined
- May 28, 2025
- Messages
- 183
My dad is on the poorer side. This past winter, I made him a Solar Air Heater to help supplement his main oil heating. It was partially altruism, but to be honest, I think I was living a bit vicariously through him because I've wanted to make these for our house for a long time, but just don't have enough consistent sun near our windows for it to work well (also, my spouse would probably veto it based on the "looks").
There were a few differences from the typical ones you see on YT and the like. One, I made a double pane. The inner layer was polycarbonate because it can take quite a bit of heat, and the outer layer was acrylic because it has good light transmission and holds up really well to UV exposure. There was about a 1.5" air gap between the two.
And while I used dark aluminum window screen as the primary heat absorber (which is fairly common), I combined it with some vertical, curved "fins" made out of Al flashing, that loosely redirected air (very loosely, I didn't want to block or strongly slow down the air). And for the top layer of the bottom of the collector, I adhered activated carbon/charcoal powder. The idea behind the latter was it would slightly slow down, and more importantly, mix the air a bit better than a smooth surface.
My dad's window had a good set up for this, because he had a regular window and storm window, so at night when not using it, he could just close the main window over it. He said that on most days, it kept his living room pretty toasty (he has a small house) even when he turned the central heat way down. (Note: acrylic is kind of a pain to bond well. If I ever make another, I would probably use super glue rather than the silicone and toughed epoxy.)
Originally I was going to set it up with having an air intake from the house, but after having a dream about the plastic melting, I decided to not do that (air intake is from the bottom, screened off for bugs and critters, with an Al flashing shroud for rain). But yes, for the most efficient design, you would want the air intake to come from within the house (I just couldn't trust my dad to open and close the windows at optimal timing. He's not as conscientious and analytical about this kind of stuff). I also thought about putting reflectors on the sides, but for the same reason above, decided to not do that either.
