Soft plastic box and lid + steel screws = stripped hole
Champlain/Hudson Valley
We've all seen 'em, we all mock how strip 'em.
They're found on some CAF housings and some engine air filters too.
Is there anything mechanics put in the hole to restore some bite?
For plastic I've used the tail end of a zip tie. Shove it in the screw hole as far as it will go, drive in the screw, cut off the excess zip tie. Sometimes you need to adjust the qty/size of zip ties according to how bad/big the hole is.
Nice. It's the plastic-equivalent of using wooden matchsticks to fix a stripped door hinge screw hole. Cheers!
