Sockets & Wrenches - For 97 Buick Park Ave
Carlostrece
$100 Site Donor 2025
NW Oregon & SW Washington
I'm going on a car trip this week (as a passenger in my car) to Lowes with a neighbor friend. This is an exciting outing for me because I'm no longer able to drive my car. I love Kobalt (and Carlyle) tools, and Lowes is beyond the range of my mobility scooter. So it will be a super fun outing!
I'm going to buy a 19 piece set of Kobalt ⅜ drive metric 6-point sockets for use on my 97 Buick, neighbors' Japanese and Korean cars, and my mobility scooter.
Do I only need to buy a ($42) metric set, or do I need to also buy a ($42) standard set?
My cousin told me that my 97 Buick's bolts & nuts that he's encountered (so far) have been metric. Does my Buick have any standard (SAE) bolts/nuts on it?
i.e. - should I also buy standard SAE sockets? If so, the entire $42 SAE set, or just a few individual SAE sockets of specific sizes?
Probably not any standard fasteners.
It's a GM car, so the most common sizes will be 5.5mm, 7mm, 10mm, 13mm, 15mm, 18mm, 19mm.... 8mm for the battery terminals... plus maybe something bigger for strut-to-knuckle bolts and CV axle bolts. That'll cover most of the car.
The mobility scooter is the odd man out, it could be cobbled together from various sources including some SAE.
Boss had a 90's Astro Van that had both SAE and metric fasteners holding the alternator on. But that had the SBC-derived 4.3. The 3.8 "should be" all metric.
You can still find fractional (inch) fasteners on brake line nuts, muffler clamps, batteries, radiator hose clamps. Buying individual SAE sockets will quickly get financially worse than just buying everything.
If you could wait until the Black Friday sales in November, Lowes always puts this KOBALT Tool Kit on sale for $99. It is a certified bargain at that price and will serve you for life...especially with the lifetime replacement warranty.
My cousin has been bringing his tools when he works at my house, but if he forgets to bring a tool it's a problem because he lives 30 miles away. So I'm tooling up a bit. 🤣
Thanks for the excellent info for bolt sizes for my 97 Buick.
What are the common bolt head sizes for 03 Honda CR-V and 11 Hyundai Elantra?
My Chinese made mobility scooter uses only odd number metric sizes (a few 7 & 9 mm, lots of 13 mm, a few 15, 17, 19, and one 43 mm). For some reason the Chinese love odd numbers. 🤷
The 43 mm nut is the headtube bearings adjuster nut. We couldn't find a 43 mm thin wrench locally nor online. So I bought the next size smaller thin wrench from Amazon. He then used a die grinder with little grinding wheel to remove just enough material to make it a 43 mm wrench. Works perfectly.
Because your buick has a 3800 there are some SAE fasteners on the engine. I would add 1/2 inch and 9/16 shallow and deep but no real need for a full set
You won't need standard sizes unless it has to do with the engine. For example, cylinder head bolts, lower intake manifold bolts, oil pan bolts will all be standard SAE. Other things that are on the outside of the engine like the alternator mounting bolts will be metric. The reason for that is because the Buick 3800 V6 goes back a long ways even before it was called a 3800.
What's the difference between a 9/16 deep socket and a 9/16 spark plug socket?
What diameter socket is needed for a 97 Buick Park Ave spark plug?
The spark plug socket has a rubber tube inside to grip the ceramic insulator. This keeps the spark plug centered in the socket.
A regular deep socket can possibly break the ceramic insulator by not keeping it centered.
You need a 5/8 spark plug socket for the Park Avenue.
Domestic vehicles tend to use 7, 8, 10, 13, 15, 18 and 21mm (except for GM SUVs and their 22mm lug nuts)
Asian vehicles tend to use 8, 10, 12, 14, 17, 19 and 22mm (except for lug nuts which can be 21mm)
That Buick will have some SAE bolts as pointed out.. Water pump, lower intake and oil pan I believe... So you'd want 3/8 and 1/2" for the most common things.
AS far as SAE and metric crossover the following are basically the same (within a few thousandths)
7mm/9/32
8mm/5/16
11mm/716
16mm/5/8
19mm/3/4
21mm/13/16
22mm/7/8
24mm/15/16
3/8, 1/2 and 9/16 do not have a close enough metric equivalent and you shouldn't attempt to go that route unless you absolutely have to.
Can a 13mm wrench/socket be used on ½ bolt?
Can a ½ wrench/socket be used on 13mm bolt?
My cousin sometimes uses a ½ wrench on a 13mm bolt. IIRC correctly, my cousin said some brands of ½ wrenches fit perfectly on 13mm bolts and work well, but some brands of ½ wrench are too small to fit on 13mm bolts. Does that sound correct?
Can a 14mm wrench/socket safely be used on 9/16 bolt?
Can a 9/16 wrench/socket be safely be used on 14mm bolt?
