I thought that about the last few Aisin transmissions I serviced, until I looked closer at the filter itselfThe filter on my camry's just a rock catcher.
I did the gasket, but bought the wrong one... there are a couple different 4 speed transmissions around.
Got a 10-pack of aluminum crush washers from ebay, good, because I did the diff drain and fill plugs as well.
You need a 10mm allen for the drain plug. Just doing one drain & fill would be under 3 quarts.
Rockauto has Aisin WS fluid for $7 last I looked.
Not being familiar with this car, but a rear sway bar addition to my pickup was amazing. I was quite surprised by how it put steering feedback into the wheel which wasn’t there before.I’ve owned one for 13 years. If there’s one absolute must upgrade for the these vehicles, it’s getting a rear sway bar. I have the TRD one and it’s a night and day difference in handling.
30 milesSome people misunderstood, I won the eBay auction, it's not free
$1426 was the final bid
I'm getting shipping quotes to get it the 30 miles or so home, because how can I drive with no plates![]()
If your transmission filter plugs up you have bigger problems.I thought that about the last few Aisin transmissions I serviced, until I looked closer at the filter itself
It uses that Filtran felt material that I'm afraid of plugging up
And the aftermarket filters aren't the same in construction or quality
Neither filter or gasket worked right on my Camry, I forget if it was Beck Arnley or ATP
If I put OE fluid/filter in, and it blows up, I did the best I could
I'm lucky my local Toyota/Subaru/Mazda parts counter people are sympathetic to my cause
I think they bill me @ List less 15-30%
That puts a lot of items within my reach
Employees get Cost+10%, which is a perk of working there I suppose![]()
...what i heard about tcw3, it could be used also for this purpose- cleaning pistons while you drive..Bring on the piston soak![]()
I'm scared to use ozone machines on interiors that old. It can damage the adhesives and you may not notice until a few months later when the headliner starts peeling.View attachment 89914
Airing out after using the generator for ~70 minutes
It finished at like 7pm last night, then it marinated till now
I can smell it across the street
I don't dare get in it to turn the key on to roll the windows down
I'll leave it like this for the afternoon, see if it's any better
... maybe too long
Edit: I'm letting it run a few more minutes on recirculate with the blower on, just to make sure the vents smell of nothing
Looks like the timing cover and valve cover are both leaking. I would reseal both and also replace the water pump and thermostat.
The tensioner is sealed with a metal gasket and rarely leaks. More likely, the timing cover is leaking at the "T-Joint" where the cylinder head, engine block and timing cover intersect. This is a common location for leaks on Toyota's....or any vehicle with a sealed timing cover. It also happens to be in close proximity to the chain tensioner.My timing chain tensioner was leaking on the 2005 Camry, not sure if it is the same, but I'll link the replacement as it isn't well documented in my searches before attempting, but everything seemed to go good with it, just haven't driven it enough to see if the symptom of what I was hearing is completely gone too, but I think the oil leak stopped, I'll have to look underneath it.
Thanks, especially for the visual, I hadn't even thought of that being a possibility though it's obvious now. I seem to remember getting a new gasket at the dealer too, wasn't readily available elsewhere. Not driving it in the winter so I won't be able to see if it's still leaking, but it was under that spot, and most likely going to be an external attempt to reseal being I'm not taking off the timing cover unless there something more to repair. Valve cover was replaced but that was ~6 years ago when I bought it, paid $5k and they are still going for that price around here.The tensioner is sealed with a metal gasket and rarely leaks. More likely, the timing cover is leaking at the "T-Joint" where the cylinder head, engine block and timing cover intersect. This is a common location for leaks on Toyota's....or any vehicle with a sealed timing cover. It also happens to be in close proximity to the chain tensioner.
Well, mainly because I bought itI'm curious why you're using an ozone generator for the interior. Were they smokers? Or just killing off stinky old car smell?
