Originally Posted By: JTK
The three-quarters of an acre I mowed with it was rough and such a small machine exaggerates the roughness. Also, on damp spots, if you tried a full turn it would plow straight ahead regardless. If the rubber friction wheel drive system gets wet, you're going nowhere until it dries.
Joel
I believe the machine you had was wore out. Sounds like gpa's snapper that he's had since the 60's. Turning wise sounds like you were trying to go to fast or the tires was wore out. Also sounds like the clutch was worn out as well never had a problem with the 4 or 5 I've used over the years.
To OP's question it all depends on the terrain and the amount of obstacles. If alot a zero-turn mower would serve you well. Otherwise I'd just find a used snapper but I'm biased. Don't know about the traction on front engine riders.
