API standards aren't really geared towards small engines. They're for modern engines with catalytic converters.
Briggs & Stratton doesn't sell an oil with an API rating these days. So it probably has some sort of secret sauce that works for small engines but isn't helpful with new cars.
This is kind of old so things might have changed, but someone did a VOA on Briggs & Stratton SAE 30 over 15 years ago. However, I'm not sure why it would necessarily be any different other than maybe the availability of base oils. They also noted that it was labeled as meeting API SJ/CF. But it had a ton of zinc and phosphorous, which would indicate a high ZDDP level. Are there a lot of small engines with catalytic converters these days?
Recently I picked up a Toro 340 XP mower, which came with an 18 oz bottle of Briggs & Stratton branded oil. Out of curiosity, I had to send a sample off for analysis (I used Rotella 30 wt in the mower). Here's what Blackstone says:
RON: This sample of Briggs & Stratton 30W oil had a viscosity in the high 20W-range. This shouldn't be a problem. No water or contamination was present in the sample. Insolubles were acceptably low at a trace level. The TBN of this sample is 9.8, and that's a fairly typical starting TBN for virgin motor oil. Calcium, boron, and magnesium perform a...
