I have been using Mobil 1 15w50 in my old Dyna Wide Glide since I have owned it. When it come to the trans and primary I used Red Line's products for sometime and they just have not been impressing me. My shifts are hard, finding neutral is a pain. I also find that the Red Line seems to sludge up in the bottom. I also killed a rear end in a truck using Red Line Lightweight Shockproof gear oil, which according to my mechanic the fluid just didn't seem to be getting to where it needed to be.
I have since been moving all of my gear oil needs over to Mystik JT7 that I can get easy and cheap at a local store. The Harley seems to like it in the gear box, but I hear those like anything. I swapped the primary over to some 5w40 T6 I had that was wet clutch compatible from the Red Line Primary lube I was running and it has made a huge difference so far. Shifts are way softer especially when cold and finding neutral has been easier.
This has made me think about looking at the other lubes I have been using. I use Valvoline Blue 5w40 in my old 7.3 and it seems to like it. I then decided to try the 5w40 in my side by side and the initial cold start valve tick on that Polaris 900 motor has been better since then. Then I was thinking, if I just cut my lawn mower and Harley over to this Valvoline Blue 5w40 I only need to buy 1 jug of oil for all of my engines. Is a 40 weight too light for the air cooled TC88? I can't imagine it sees much more extreme pressures then the old 7.3 right?
