Slotted screwdriver recommendation
JHZR2
Staff member
New Jersey
What’s the best modern version of a USA made screwdriver that’s exactly like my Hardware Industrial Tool brand slotted?
This one is old enough to predate zip codes. It’s Phila. 21 USA.
I’d like this exact kind - no frills hard handle, hex on the top near the handle, etc.
Must be USA made.
Samstag has used ones but I suspect I can get new for about the same.
https://www.ebay.com/itm/3052646874...Dye2EBISLK&var=&widget_ver=artemis&media=COPY
Recommendations?
Thanks!
I see nothing wrong to it. Put the tip into a grinding wheel or sharpening stone to have a straight tip, and you'll end up another 100 years use to it.
I see nothing wrong to it. Put the tip into a grinding wheel to have a straight tip, and you'll end up another 100 years use to it.
Not the point - the one I have is great. I’d like another.
View attachment 239354View attachment 239355
Must be USA made.
Recommendations?
Thanks!
Here is one like yours, not sure it's as old
https://www.ebay.com/itm/3052646874...PBsRITOM9dUk/QF7/t4PJcfm0=|tkp:Bk9SR7iyiqq6ZA
Williams - made in the USA. Hardened tips. Hex on the shank for a wrench if needed.
The square grip is different, but I have come to really like them. The fit my hand well, and don’t roll when you put them down.
https://www.amazon.com/Williams-100...61&mcid=f482667e022d3b7e8fca4c0024f41140&th=1
Those are the old Snap on from 1971 (when I started using them in school) and probably earlier to the point they put the Williams branding on them. One of the best screwdriver sets you can buy.
I recommend the Snap-on/Williams like what is listed above. I absolutely love those handles and they have the hex as well too. They are my first grab if I need a screwdriver. The tips are very good too.
