So I started finally to put engine back together, but forgot to oil everything up and had to leave it open for a week, and since this year it's been raining nonstop for the past two months, it developed some surface rust on cams.
So far I have used scotchbrite with wd-40 on gears that connect two camshafts and rag with wd-40 on lobes and journals. I have added pictures of the cams from worst to best. This is a daily with an OM642 engine. Hard to find any specific information on the issue so any input would be appreciated. Are all of those cams scrap or could I save some/all of them?
1. Camshaft
Went about 40 light passes over this with 2000grit sandpaper and WD-40, got a lot better but unsure how long would be okay to go over this until too much material would be removed, since I think all of them would clear up with some further polishing.
These are the worst teeth on gears after scotchbrite and wd-40, total about 12 teeth, some pitting on one side only. Should I touch them also with 2000 grit or rather not, how much stress would be on those and how deep is the hardening?
2. Camshaft
Not sure if this is pitting or just some wear that was there before. Around 10 teeth with same/less pitting than on 1. camshaft.
3. Camshaft
Same/less wear on journals/lobes as 2. Around 8 teeth that have same/less pitting than on 1. camshaft.
4.. Camshaft
No pitting on gear teeth. Just some minor wear marks.
1. Camshaft
2. Camshaft
3. Camshaft
4.. Camshaft
