Originally Posted By: Deamos
How short are short trips?
In the mornings I go to the office it is about 4 miles one way. the 2 days a week I work form the house I take my son to daycare and that is about 2 miles round trip. Allot fo time I will go exercise and that is either 5-10 miles round trip depending on where I start from and the truck will sit for an hour while I ride. Now that the spring semester has started, I drive to grad school 2 nights a week and that is about 35-40 miles round trip.
Originally Posted By: gregk24
Change it, dont try to outsmart the engineers that designed it.
Normally I'd agree with you, but the engineers designed to a certain parameters (conventional oil in 2001), I have since changed those parameters.
Originally Posted By: mrsilv04
This shows that the OLM knows that you've been making shorter trips.
There are people who will try to convince you that the OLM in GM vehicles simply counts down miles. It doesn't.
It is your decision to change now or wait. I don't think you're going to make a mistake in either choice. You're not in a cold weather climate like I am, where those short trips could be leading to condensation issues. In addition, we've seen temperatures from 50 above to 20 below so far this winter.
If you were up here where I am, I'd tell you to change it. But in Texas, I'd wait for 5000 to roll around.
When I was working out of our other office, I was doing 40-60 miles a day and a couple times I forgot about the oil change and the light didn't come on for 6-7K miles. It definitely takes more than just mileage into account.
Originally Posted By: Clevy
I have a 99 silverado, basically the same truck as yours is. The oil life monitors take into consideration rpm,oil temps,idle time,and a multitude of other variables before that change oil pops up on the dash.
Our trucks were calibrated for a conventional oil an SL spec iirc,so today's offerings are far better than what was originally specified so yes you can run another 1200 miles before changing the oil.
In fact Mobil guaranties the M1 line for 10000 miles so you are in fact dumping oil with half it's useable life left.
We've got a member here named SteveSRT. He's got a fleet of Chevy 5.3 and 6.0 engines in vans. These vans operate carpet cleaning equipment so the engines run non stop all day because not only do they power the vans and get them to the job,they also power the equipment.
From what I remember SteveSRT uses whatever synthetic is on sale and changes the oil according to the oil life monitor.
His duty cycle is easily the most difficult I can think of yet his engines run many hundreds of thousands of miles.
In fact he was bragging the other day that he had a 6.0 that was just sold at 500k miles and the van had nothing but routine maintenance and the engine never opened,just oil changes.
So your duty cycle isn't severe so I suggest running the interval longer or run a conventional and save a buck.
Don't fool yourself and think running syn and dumping it half used is "cheap insurance" because it's not.
Any of today's conventional can run 5000 miles except in the most extreme circumstances such as all towing miles or all city miles or all short trips.
I think it is the "RPM" that is setting it off. the bad or good part about where I live is that the south side of my street dead ends into a major freeway and I go west I am less than 2 minutes from another major freeway. Especially in the afternoons, just getting into traffic to go ride or get to gradschool requires a liberal use of RPM or you sit at the stop sign for hours.
Originally Posted By: 2010_FX4
The truck is far out of warranty. One or two used oil analysis would tell you how healthy the oil is allowing you to extend it past 5K. M1 can do 10K without breaking a sweat in mixed driving--an used oil analysis would tell you for sure.
I do need to do a used oil analysis, I usually try to keep it to 5K, since by then I am usually down about a quart.
