You are exactly right on all points! They tried to shorten OCI's to combat the timing chain epidemic but that didn't work because the real problem was the chains themselves.GM didn't program and hard limits in the OLM until around 2011, when dexos first came out. For most cars, it became one year of 7500 miles max. The exception is the Volt, which is 2 years max, no mileage limit.
The limits were implemented after they started having problems with some of the HF V6 timing chains with DI. That's also when they developed dexos.
Older GM cars with the OLM have no limits programmed in, but the owner's manual said not to go more than 12k or a year.
On your truck, that's less than 1000 miles in a year. It probably is OK to only change it once every 3 years with such low use.
One of the two characters in the tv sitcom about a couple of ladies that worked in a Milwaukee brewery?How many people know who Shirley Schwartz was?
Hondas is supposed to be intelligent, but I'm not so sure. 1800 miles on my FL5 and the monitor is at 90%. I have 1 mile short trips to the gym, on the highway the thing is spinning at 3600rpm, and I drive it hard in the twisties. I'll stick with changing at 3k+- so all it really does is remind me to check other maintenance things.
It was Shirley Feeney on Laverne and Shirley. I watched that show when I was a kidOne of the two characters in the tv sitcom about a couple of ladies that worked in a Milwaukee brewery?
Oil monitors are like my alarm clock, just advisory. My Ford OLM went to almost zero once and when I prompted it, the thing told me I was a Publisher's Clearance House Winner.
5K or Q6 months for me.
She’s the mother of the GM OLM. Brilliant lady.
This is not correct, it may light up and warm you at 15% but that’s not when you change the oil.See how long it takes to get to 15% which is when Honda wants you to change it. The first 1800 miles/90% left doesn't mean it will suggest an 18k OCI! Possibly, there is enough 3600 rpm highway driving to offset the 1 mile trips to the gym and the twisties
Poor man's OLM.
Change oil by amount of fuel used. Does close to the same thing.
250 gallons?
