My '06 Sierra with a 5.3 sees mostly rural (55 mph) miles and will only go about 4-7k miles before the OLM reaches 0%. I've done 2 used oil analysis (both at a little over 4k miles) and both came back with higher than desirable fuel dilution, so I don't consider my truck driven under my conditions a good candidate for extended drains. I currently run dino with 3 changes per year, which is about 4k miles. Two changes a year would be about 6k miles and I can't make it that far according to the OLM (at least in the colder Ohio months).
I have considered going to twice-a-year/6k with synthetic (extending the drain intervals a little). But quite frankly, I don't consider most of the readily available “synthetics” that much better than SM dino for my application. Although the more readily available “synthetics” do meet a few more stringent specs, from what I understand those specs don't really address an oil's performance in the presence of fuel dilution.
Some of the 5.3s had issues with head gaskets, not sure about the 2007s. Many also tend to fuel dilute the oil like mine. Given all that, I would never consider extending the drain intervals for my truck beyond 10-12k on any oil, even one recommended for 15, 25, or even 35k (but no more than a year). And I wouldn't even try going beyond 8k without a used oil analysis.
Although you drive more highway miles, I'd be surprised if any oil wouldn't be well spent before 15k miles in your truck. With your driving, I'm guessing your OLM reaches 0% at somewhere around 8-9k miles.
Since you had an engine “failure” and possible sludging, get a used oil analysis done at about 4-5k miles and look at the fuel and glycol levels. If both of those are good (fuel under 0.5% and no glycol/antifreeze) you may want to consider resuming extended drains with Amsoil (but not without supporting used oil analysis at 5k intervals [starting at 10k] up to the 1 year point) to establish a safe oil change interval.
