The other day I watched the last of the "Ultimate Factories" DVDs I took out from the library. They were all tours--with an extremely obnoxious narrator--of automotive factories. I was surprised, most of all, to see that Bentley, Rolls Royce, and Lamborghini are actually expensive to produce and are made with a lot of human labor. Perviously, I'd seen them as mostly Veblen offerings from their parent companies.
One thing I noticed is that, for all the intricate labor and machining and parts selection, I didn't see a single silicone hose or polyurethane bushing in any of them. I can sort of understand the reason for using rubber bushings, even though there are softer urethane compounds that should perform similarly, but I can't wrap my head around the use of a rubber radiator hose in a Rolls Royce when they just as easily could have used silicone.
If this solely due to cost cutting, or is there an engineering reason for using these parts?
