Here's a "quick" (might want to grab a cup of coffee) update on my '98 Sienna (151k miles) -
History -
1MZ-FE "sludger" engine.
Bought at 62k miles.
80k miles (62-140k on M1)
Oil consumption was consistent (last several years) at 1 qt in first 1k and 1 qt in subsequent 1.7k of an OCI.
Last Summer (2007) - 500 mile Neutra 131 run.
Last Thanksgiving - 1k mile Neutra 131 run.
Filled with Schaeffer 9000 5w30 - ran this from end of November 2007 to early April 2008 (3.75k miles - perhaps two 150mile round trips on this, all other miles were mostly 3 mile round trips - will post my used oil analysis "soon").
Consumption after Neutra runs had dropped perhaps by 40-50%. Thought I might have a slow leak (later notified by brake mechanic that I had a slow leak from the oil pan - so slow that there are no drips).
Installed Schaeffer 15w40 in April (I was thinking the leak was insufficient to account for consumption).
Consumption at 1k was unchanged w/ the 15w40. Since I'm now in a period (and have been for about six wks) of very high mile trips (will average out to about 1k every two wks between now and July 4th) - I decided to try something ...
Bugging me in the back of my mind was what I read last year by AEHaas - that is, thin oils possibly lessening consumption. I like to do long OCIs, and having high consumption (and thus frequent top-offs) runs counter to the philosophy/theory/practice of the long OCI (very frustrating). I was going to be bummed if I never gave Haas' theory a try - so, I decided to take advantage of this period of high miles to test things. I dropped the Sch. 15w40 out (into a clean, air tight container - I'll find a use for it), and I dropped in Penz. Plat. 5w20 (it's thin among the 20w's) (btw - haven't chged my PureOne filter since last November).
I'm now at 1.2k on the Pennzoil Platinum 5w20. Consumption is either equal or less (definitely not more) than the 15w40. In fact, out to the 800 mile mark, there was almost no discernable movement of the oil level from the "full" mark on the dipstick. I haven't seen an oil do this in this vehicle in about five years.
Conclusion -
All the conventional wisdom is - thick oils for older engines, thick oils for consumption. This Toyota engine may not be old yet (may still have new tolerances), but there is the consumption issue. 5w20 hasn't fixed my consumption (perhaps it's all due to the oil pan now), but it's definitely not consuming at a higher rate. So it can be said that in this engine, a thin oil does not lead to higher consumption.
A thin oil helps my peace of mind in this vehicle that can go the whole school year on mostly 2-3 mile round trips (school, church, Walmart, groceries, restuarants - all are very close). I'm not totally at peace w/ PP in this app (esp. since it's now going to see heavy and hot hiway miles). PP didn't score well on Amoils heat resiliancy test (compared to Amsoil and M1) and this engine is known for heat - but I'm planning to leave it in till around Thanksgiving and then used oil analysis.
Thank you for your time.
History -
Conclusion -
