Shower head restrictor
Woodbridge, NJ
So I use a rainfall shower head. When I first got it I removed the water restrictor and my showers were awesome. High pressure to quickly wash away the soap so that I don't have to rub and rub the soap away. Problem here is the water usage. My house has a 40 gallon water heater and it can't keep up with the shower head and no restrictor. So I bought another of the same shower head that comes with a 1.75 gpm and a 2.5 gpm restrictor. I am using the 2.5 and I am not happy with it. I need something between the 2.5 and the deleted restrictor. Has anyone ever modified a restrictor so that it will flow somewhere in the 3.5 gpm to 4.0 gpm? If so what is the best approach? I thought about drilling a few small holes through it but I am not sure that will actually work. Please advise if you can. Thanks
Don
Don
Does the head have threads ?
https://www.build.com/product/summa...MI273_q9r5jgMV4yzUAR0fGjPoEAQYASABEgIQwfD_BwE
Don
Drill baby drill!
did the internal restrictor have a small little o ring ......and if you remove the o ring, it reveals a thing that puts you in mind of a strainer?
Check out the difference in size between the two restrictors you have and maybe try drilling it out more and see how it goes? You can always keep going bigger/test/trial and error?
I will have to chime in on this post, because I recently purchased a Kohler shower head that was something like 1.4 GPM water flow rate.
So as I stand in the shower twice as long to get fully cleansed my neighbor is running his outdoor sprinkler with no concept of timer and is having a flood down the street pretty much every day!
My point here is yes we're trying to conserve water in SoCal but I see this as if anybody remembers
the cigarettes that were low nicotine with a special filter to reduce the tar.
It was like smoking an air cigarette you had to smoke three to get the benefit that you were looking for.
I know this might be a strange analogy but standing in the shower twice as long and using the same amount of water reminds me of that when I used to smoke.
Long story short the restrictor came off and I also called the manufacturer and they sent me out another one with a better flow rate. Just my two cents here.
This may work. Water heater is set one step down from hottest temp. When I removed the restrictor the pressure from the shower head was amazing. Made the shower curtain flap around. Not sure what the gpm was without the restrictor but I figure it was at least 5 or 6 gpm. Probably more. The current 2.5 gpm just isn't enough. I need more but not a lot more. And to the member who suggested taking shorter showers. My normal shower time is about 4 minutes. Unless I am shaving my head and then it goes up by about 3 minutes. So my shower time isn't terribly long. I forgot to add that with the restrictor in place the water heater keeps up perfectly fine. I will give the valve a shot and cross my fingers.
Don
  • Like
Reactions: 4wd
The typical size tank is 55 gallon. I had a 75 gallon installed when I bought my house. Builder thought I was nuts... Women take long showers. Wanted to make sure if I was last in line for a shower, I had hot water...and I do. Everytime. Too many cold showers when I was growing up. Wasn't happening again !!!! PTSD !!!! LOL :)
