As a lot of you know I just got my explorer out of the shop. They changed both valve cover gaskets, the lower oil pan gasket, pcv and the airfilter.
The tech refilled the engine with PU and installed a Distance+ filter.
Is there any reason I should shorten the oci? I would think the filter will catch any contaminates but im not as schooled on used oil analysis as some of you.
I was actually kinda wanting to run it 8k or more...
