I imagine they just settled in the bottom of the pan below the pickup.
I eventually traded the car in at less than 40K miles because by then I was pretty disgusted with it...the dealer refused to fix a bad flare with the first few 1-2 shifts on cold mornings because they said it was a "characteristic" of the car, distorted audio when listening at low volume levels, the driver side power window regulator would occasionally jam, it would frequently stink of Dexcool and needed to be topped off regularly...the dealers "solution" for that was to tape a piece of rubber hose to the top of coolant surge tank, and after they replaced the A/C compressor because it sounded like it had rocks in it--the A/C never worked correctly again. After the warranty was up I figured it was best to part with it before it got any worse.
It was a shame because I thought it was a really nice comfortable car. Must have been assembled on a Monday or something...
Originally Posted By: kschachn
Originally Posted By: W3DRK
I had a 2012 Cruze with the 1.4T and my OLM was the same. Twice I let run all the way out to 10K and both times I noticed some "chunks" come out with the oil when pulling the drain plug which I assumed to be result of turbo coking. And this was with QSUD 5w-30 in the sump if I recall correctly. After that I limited my OCIs to 7500 mi and the "chunks" seamed to clear up.
I'd be equally concerned why the oil filter does not capture visible chunks.
