I was reading the "look I made sludge"
post and it seems that some of you guys are using short drains to presumably clean up the engine a bit.
I'm pretty new here, and constantly trying to learn.
My question is, how short? Is 500 to 1000 miles considered short--and beneficial?
I know all about the Auto RX stuff. If it were cheaper and readily available I'd be more interested. I may actually try it some day.
But until then, what might a high detergent oil--with perhaps a good solvent additive like Marvel Mystery Oil do with a couple of quick changes? I've found the MMO for as low as 3 bucks a quart and I can say that it definitely does scrub the engine to some extent (oil darkens very shortly after pouring in the MMO). So with a couple oil changes that I'd have less than ten dollars each in (counting the MMO) might I at least move enough sludge out of my engine to give some benefit?
Dan
Dan
