TooSlick's Amsoil 5w-20 in his Tacoma(?) was questionable. I believe he was going to try synergen 0w-20 next. Any results yet?
I believe his Toyota doesn't call for 5w20 though, so he was experimenting. So in reality we could then say that 5w20 hasn't shown terrible results in the engines who's owner's manuals specify 5w20.quote:
Ah, therein lies the question. In vehicles that call for 5w-20 does thicker REALLY mean an added safety margin? I haven't seen any evidence to support that claim.quote:
Originally posted by TallPaul:
......in light of the added protection margin of safety with a thicker oil.
quote:
[qb] Cars using 5w20 possibly have better oil cooling than previous versions requiring thicker oils.
Oil gets too hot, its toast regarless how thick it is.
Give me thin oil and controlled oil temp any day.Engine that from one model year to the other have had thinnewr oil recommended were UNCHANGED from teh previous model year with thicker oil recomendation.....
I think the link above explains it perfect.
I will I link it, on my 11,000 member, 15 million hits/mo site, as part of our favorite links list.
Fred..
[ October 29, 2003, 08:02 PM: Message edited by: palmerwmd ]
I'm no engine builder, but my guess would be that once the engine gets significantly worn out, it's no longer nicely balanced, so things like the bearings will end up wearing out at a much faster rate, thus dumping more lead into the oil for instance. Same with the valvetrain, as it wears out and isn't running as smoothly, it dumps out more of it's materials into the oil too. Then all of those metals combined just continue to do damage and a domino effect takes place. (this is all speculation on my part by the way)quote:
Originally posted by Dr. T:
Jason, why would wear metals go up in a worn-out engine?
Wow that is really weird, I've never had an engine that consumed oil like that.quote:
However, every car I owned from 4 cycl. to 12 consumed a 5w-30...guess if one doesn't have any consumption issues with a 0-20 or 5-20, then they should continue with it...I've yet to see an engine that didn't...maybe that means the ideal viscosity is one in which one has zero consumption.
Bearings for instance usually get out of round, they turn into an oval, wear they wear on the tops and bottoms. This creates a jackhammer effect from the power of the engine. The farther out of round the harder the stress on that bearing becuase of the looseness of the bear, therefore it compounds the effect of the wear.quote:
Can you prove this theory?quote:
Originally posted by metroplex:
Years back when 10W-40 was used year round even in cold climates, it was used in engines with looser clearances.
