Licensed. The API does not approve an oil.If it was API approved then it would get the SN inside the donut. In this case it may not be official but meets SN specifications for the grade.
And can you even get a new SN license?
Pretty sure they've been SN rated for many years now. Shell elected to not have SN rating on their Diesel oil when they went to CK-4.At Kum and go and I see Valvoline 15w40 is also SN rated..
Really? You knew what I meant.Licensed. The API does not approve an oil.
It goes to the heart of this discussion. Language is important because I don’t think you can get a new SN license.Really? You knew what I meant.
I figured there was a licensing "approval" process when trying to obtain API specifications. Is there not? I thought I'd read that's the wording they used. Approval Process. It's already been said that this oil appears to not be a "Licensed" SN oil.It goes to the heart of this discussion. Language is important because I don’t think you can get a new SN license.
I found this requirements pdf. Cracking open a diet root beer...I figured there was a licensing "approval" process when trying to obtain API specifications. Is there not? I thought I'd read that's the wording they used. Approval Process. It's already been said that this oil appears to not be a "Licensed" SN oil.
Turns out they use the word "Approved" 90 times in that pdf document. They talk about "Approved" add packs, "Approved" engine tests, & more. Certainly seems reasonable to say "Approved" oil since "Approving" is most of the process.I found this requirements pdf. Cracking open a diet root beer...
https://www.api.org/products-and-services/engine-oil#tab-requirements
https://www.api.org/products-and-services/engine-oil/documents/api-1509-documents
https://www.api.org/-/media/files/c...iesel/publications/api 1509- 21st edition.pdf
Yes they have approved additive packs and approved tests. Of course they do. But the end is a license, not an approval.Turns out they use the word "Approved" 90 times in that pdf document. They talk about "Approved" add packs, "Approved" engine tests, & more. Certainly seems reasonable to say "Approved" oil since "Approving" is most of the process.
The end is the result of approvals. That would mean approved licensed oil. The whole License process is based on approvals.Yes they have approved additive packs and approved tests. Of course they do. But the end is a license, not an approval.
You keep trying, I'll give you that.The end is the result of approvals. It's approved licensed oil.
You keep getting whirled up about me saying "Approved Oil" as if Approvals have nothing to do with Licensing requirements. It does. Oils must get "Approvals" to get licensed period. It's reasonable to make a statement of "This oil has a CK-4 License Approval".You keep trying, I'll give you that.
I'm not a lawyer, but not really. I think its an approval to be akin to a "club" member so you can put a licensed sticker on a bottle as long as you pay your annual dues and per gallon fee. The manufacturers technically "approve" but I think i've only seen they "recommend" the particular API license. Some manufacturers make up their own programs, ie BMW LL01, etcYou keep getting whirled up about me saying "Approved Oil" as if Approvals have nothing to do with Licensing requirements. It does. Oils must get "Approvals" to get licensed period. It's reasonable to make a statement of "This oil has a CK-4 License Approval".
With all due respect I find it reasonable to say "license approval" in communicating api standards. I find it hard to believe that most would have any issue & understand what I mean by that. Like I said.. probably 90% is an "approval" process to get the license itself. The license application itself needs to be "Approved" for crying out loud.I'm not a lawyer, but not really. I think its an approval to be akin to a "club" member so you can put a licensed sticker on a bottle as long as you pay your annual dues and per gallon fee. The manufacturers technically "approve" but I think i've only seen they "recommend" the particular API license. Some manufacturers make up their own programs, ie BMW LL01, etc
Digging deeper on their site, they offer courses to individuals, certifications for those courses, they sell "standards" for other industries and so forth. I dont think they do any actual laboratory testing. They define the tests, check for compliance, maintain rosters, and generally do "paperwork."
Grab some pic's if you can.i think ( i dont remember specifically) i was looking at some rotella t6 5w-40 at waLmart and saw it was sn rated. so is Valvolines 5w-40 diesel oil. Amsoil too.. ***?
