Shell Rotella 05w40 Synthetic at WalMart
Originally Posted By: carlsberg1664
chevrofreak, Does Mobil 1 contain dino ?
Many Mobil 1 oils contain significant amounts of Group III base stock.
Originally Posted By: Brewmaster
Group IV oils are compatible with petroleum based oils and fuels plus they have better seal swell than petroleum based oils.
Sorry, but, that's not true.
dsmith41 you are correct.I wanted to know if it was REAL synthetic (like Mobil 1) (man-made,no dino) Thanks to all who responded!
Yeah, like they said. Sorry to burst your bubble but M1 is not a TRUE synthetic as you call it.
Let's not forget that nearly all PAO products (like Mobil 1 and the other brands) use some Group II+ or Group III in them.
Brewmaster talked of PAO benefits, but not the limitations. Let us understand the PAOs do NOT hold additives in suspension nearly as well as lower group oils. So, while the viscosity attributes of PAOs might be appealing at face value, they do not do much, if anything, for anti-agglomeration (co-joining of soot and insolubles), nor do they hold detergents as well. Yes, PAOs are excellent at temperature response (cold) and resistance (heat), but they stuggle if not assisted, to do other things.
So, there is no really "pure" PAO on the market. To varying degrees, they all have some amount of group II+ or III added to them to help hold the add-pack toghether.
I am willing to understand that some people want to split hairs with the wording of "man-made versus dino". But look deeper, and realize that they are all man made products! Show me ANY lubricant that comes straight from the place of origin, and is put in a crankcase or transmission, with zero assistance from human intervention? Folks, ALL lubricants are manipulated by man; they have different base stocks, add-packs, viscosity ranges, etc. Every single product we discuss here is "man made". Why? Because they are products marketed to a target audience; the expectations of performance dictates how much of chemistry "A" and how little of chemistry "B" are needed to satisfy particular criteria.
Even your precious PAO group IV products would fail in everyday long-term use without the blended assistance of dino fluids helping to carry the add-pack. Just like in life, it takes cooperation to make the world go around.
So, when someone says they want a "real synthetic" I have to chuckle, because they really have no idea what they want, nor how to get it.
If they were to say: "I want a high quality lubricant that has a base stock capable of extended OCIs without the assistance of bypass filtration, with a robust additive package assisted by lower group oils to hold everything in suspension, for a blend that will resist oxidation, flow well at extreme cold temperatures, hold insolubles at bay, scrub out previous remnants, and provide great wear protection. What oil should I get?"
Here the correct answer is "get a PAO based group IV oil like Mobil 1, Amsoil, etc."
But someone could also ask: "How can I get these same performance criteria, with lesser cost?"
The answer is a group III product, with more VIIs to mimic the viscosity of a PAO base stock. Consider RTS or Syntec or SynPower or PP, etc."
They are all blends to some degree; the question becomes
1) what do you "want"?
2) what do you "need"?
3) what are you willing to pay for it?
As I said in my first post of this thread; there are those that understand "synthetic" is a marketing term and there are those that do not. To call one product "real" is to infer the other is not. "Real synthetic" is a term that holds no value, because nothing on the mass market is "pure PAO" anyway.
The problem we all stuggle with is in looking for quick answer to a question that really is factually challenged. We're attempting to provide a simple, single sentence reply where none can suffice. How do you answer a question (is it a "real synthetic?"), when the question does not define what the expectation of the words "real" and "synthetic" are supposed to mean?
If the OP asked "Does RTS have the same marketed methodology for compsition as other high end PAO-based products?" We'd all say "no".
But when the OP asks if RTS is a "real synthetic", they we all have to play this game going round and round about what the words "real" and "synthetic" mean.
The problem isn't with the answers; the problem lies in the question!
One synthetic that not too many owners mention. In which I personally believe is in the same category or above M1 & Amsoil----->Redline! and of course it comes at a very high price. Averaging from $9 to $12 a qt.
But Agree 100% with dnewton & all his comments.
Carlsburg don't read to much into the Full Synthetic B/S.
{WITH GOOD ROUTINE MAINTENANCES HABITS!}99% of the time any of the so called synthetic oils will lubricate and cool and clean your internal engine parts for the life of the auto as well as yours. Use a good filter and keep it fresh and clean. Nothing complicated about that.
Main strength of synthetics-->Cold weather pump ability and extended drain Intervals{along with UOA}-->w/single or dual by-pass system installed.
P.S. Rotella T Synthetic 5w40 is a strong performer-->At a decent price compared to other synthetic 5W-40 oils.
In addition to all this, you can tell by the charts in the following article just how close GIII bases are to PAO performance
http://www.machinerylubrication.com/article_detail.asp?articleid=533
You can see that while not exactly the same as PAO in performance, GIII oils are much nearer to PAO in key properties than they are to GII oils. At some point it becomes the splitting of gnat hairs, and we are pretty close to being there.
Nearly all PAO? Last time I checked, M1 products contained 5-10% PAO at most.
I apologize, Q-Pete.
"nearly all" = most all of them in that market. Not, "mostly comprised of ...". I was being "mostly" inclusive of the PAO products as a market group. I did not mean their percentage of base stock in that comment.
Hope that clears up my statement.
I'm not really sure what true percent of base stock the "PAO" group IV products have, as a generization.
My point is that all the "synthetic" products, whether they be III, IV or V, are all "blends" of base stocks to achieve things we desire. We ask so much of oils today (longevity, temps extremes, cleanliness, etc) that they have to be all things to all people. The only way to achieve that is to NOT be "pure"; rather, they are blended towards their target market. And the base stocks and additive packages are adjusted accordingly.
That is why "real synthetic" is a myth; it does not exist, in the "pure" sense.
